I like to scour the Internet for things to add to terrain for features and what not so thought I'd start a thread with some links to some useful items that might help add colour to your terrain. Feel free to post things you find that might be of use to anyone.
http://bit.ly/Uhy8kB
This collection of cogs is cheap and would look great as pipe valves or to break up bare walls.
http://bit.ly/RFXElU
Is your scenery not powered by enough skulls? Stop being a wimp and add more. Too few skulls makes the zombie emperor cry.
http://bit.ly/18twusr
These flickering tea lights can add light to your terrain. They're compact too so no need to worry about hiding wires.
http://bit.ly/19rN8qB
This can be used to cast some plaster statues at the entrance to a factory or something.
https://slatersplastikard.com/plastikard/embossed.php
About three quarters of the way down there's single and double plate tread. 1:50 is the correct scale for what we need.
http://bit.ly/UEk8n3
This stuff is magnetic tape. I use it edge my terrain and put some on the bottom of walkways. Remember though, you need a roll of type A and a roll of type B. Opposites attract and all that.
http://bit.ly/V6qkZ7
Though this seems really expensive, it works out cheaper than buying white sheets. Plus with black you don't need to spray things to undercoat them. Foamcore is essential for building things. White or black, it's your friend. To keep the edges really neat always use a new blade to cut it. That way it won't look like you've cut it with your teeth. If your teeth are neat then no problem. But if you look like you could chew an apple through a tennis racket, then use a proper hobby knife. Your dentist will thank you.
http://bit.ly/19rNVHZ
This makes awesome corrugated iron. You can also use it to make shipping containers by following this guide.
http://bit.ly/W2ouTP
Plasticard! Or styrene, it's all the same. This is good for all sorts of stuff, get some. Get some now!
http://bit.ly/19rOf9E
This mesh can be used as fencing or for walkways. You decide.
http://m.homebase.co.uk/mt/www.homebase ... Cookie=yes
This stuff can be painted up to look like concrete. I'm pretty sure I've seen this very stuff on some of the old GW scenery. It's good like, and if you make a mould of it you have all you'll ever need!
http://bit.ly/13MCGWj
These computer fans make great entrances to ducts of for great big banks of air compressors and what not. And they're cheap! If you keep your eyes peeled you can get some great bulk deals on these. I got ten for 8 or 9 quid.
Ill put more stuff up if anyone finds this useful. But as I said, stick your own secrets up if you want. Hopefully it will inspire someone or provide that thing you've been looking for but didn't know what it was called.
