Shriken is PRINTing 3D stuff: mordheim, 40k and more (with lots of pics)
Kommissar Shriken
Nov 21, 2016
1,230
5,742
143
Regensburg
Hello Yakkers!
in this thread i want you to show my experience and prints with my new 3D printer. Santa Claus brought a fantastic maschine and since christmas it works about 24h daily :) .
Printer:
The printer is a Anycubic 4 max pro printer. without any upgrades. directly out of the box.
i wanted a printer with a case, so my son could not put his little fingers in it... and also, i did not have to assemble any parts: ready for print directly out of the box!
In the printerbox also came a sd card with some testfiles and a programm to configure the files before printing (quality, speed, temperature and more).
its a PLA printer, so theres a thin plasticfilament that gets melted and added to the warmed plate -layer by layer... PLA is perfect for making cheap/big things like terrain and buildings, but is not very usefull for miniatures, because with this technic you cant print fine details...
The software is called "cura". it was an very old version, but after installing you can update to the newest version. first i was overwhelmed with all the things you "can" configure in the programm.... but i dont have to do much of the settings, because normaly you simply load/import a finish profile from your 3d printer brand and than there are just a view details you have to configure befor you print. important are at first the support-lines (the programm adds them automatically, but you can chose how much of them you need) and the adhession -lines (simply said a thin base, so the peace you print could not slip away while printing)
that thin base are the adhesion lines. it was my first test-print and i added not enough of them, so my print was a little bit damaged.
WHERE to get files? I just say https://www.thingiverse.com/ ... jeah of course there are a hundrets of sides where you can get files for free or a view pounds, but thingiverse has sooo much files in great quality for free.
so here some examples (most terrain peace for mordheim)
...look at that fantastic house...... i love it!
Punktaku
Un-Dis-Honored
Apr 4, 2017
7,480
12,526
228
Connecticut, USA
So that grainy texture in the last photo, is that the print lines from each pass of the filament? Can those be filed smooth? Is there ever an issue with them separating with the new printers?
The detail looks pretty good, but you say it’s not refined enough for minis? Could it be used for something like armatures or body blanks? Then you could GS details on or “dress” them with bits or other parts.
Reactions: Gstoe
Kommissar Shriken
Nov 21, 2016
1,230
5,742
143
Regensburg
yes it is. i made this print with 0,01mm high lines, so this lines are very smooth. when you use a spray-primer, i think you need to make some more colour layers to fil most of the lines.... for sure the quality with a FDM will never be like a resin-printer (SLA).... the FDM is just made for big sizes and "easy" forms... with those complex forms like a face, wires, buttons and more, the FDM makes very "shaky"lines.
for example: here's a centurion-torso.... very ugly...
cainex1
Dec 8, 2017
2,223
2,912
123
USA
Hrm... mine will only go to .04.
And are you sure thats on .01 or .1?
Anyway, I'll be watching this thread because I need to figure some things out so I can use this thing once I get it assembled.
Kommissar Shriken
Nov 21, 2016
1,230
5,742
143
Regensburg
you are right: with the 0.4 nozzle i can print max to 0.1. for thinner layers i had to change the nozzle.
Here the complete spezifications:
Technical Specifications● Printing Technology: FDM (Fused Deposition Modeling)● Layer Resolution: 0.05-0.3 mm● Positioning Accuracy: X/Y 0.0125mm Z 0.002mm● Supported Print Materials: PLA, TPU,ABS, HIPS, Wood● Print Speed: 20~80mm/s (suggested 50mm/s)● Nozzle Diameter: 0.4 mm/1.75 mm● Build Size:270mm(L)×205(W)×205mm(H)● Operational Extruder Temperature: Max 260ºC● Operational Print Bed Temperature: Max 110ºC● Extruder Quantity: Single● Input Formats: .STL, .OBJ, .DAE, .AMF● Ambient Operating Temperature: 8ºC - 40ºC● Connectivity SD Card, USB Port (expert users only)● Package Weight: 18.5kg
Bilbostomper
Laser Monkey
Nov 30, 2017
731
1,754
Porsgrunn, Norway
Congratulations! :D
I hear there's a technique you can do with a gas of some sort that smoothes out the print lines. Haven't looked into it much myself, but it could be worth checking out. What's the largest volume you can print?
cainex1
Dec 8, 2017
2,223
2,912
123
USA
Congratulations! :D
Mine will handle 200x300x300mm
Cross-posting the link to this into the thread of
I will be making use of this! I might have to post some of my own that I've been curating.
undertaker
1,315
2,324
188
Nottingham
Congratulations! :D
The technique for smoothing the prints uses acetone vapour to dissolve the surface. You lose some of the detail in the process, but for some things, like your stone house for example, it wouldn't matter so much.
cainex1
Dec 8, 2017
2,223
2,912
123
USA
Wow, that's huge. The ones we have at work are 100x100x100 (but then we have 15, so it kind of makes up for it...).
I got a double whammy good deal, backed a kickstarter for a good but inexpensive printer and then they had to clear out their warehouse. They gave backers the option of putting their money towards their high end printer and had it on a black Friday deal... so I jumped! I got a £800 printer for just shy of 300
Halbling
Dec 28, 2015
346
1,231
108
Karlsruhe
Impressive stuff Kommissar! The buildings are looking really really good. How much time did you need with the printer and the software before going „productive“? And where do you source your material?
Is there any smell or health risk while printing? I’ve seen some on industrial level and they are very careful regarding these issues.
I thought about buying a printer as well but I don’t have enough space, but these results look very promising and one day I will get one myself.
Kommissar Shriken
Nov 21, 2016
1,230
5,742
143
Regensburg
i read that the aceton works only with ABS plastic. PLA does not dissolve...
i actually use PLA because i often print more than 24 hours and PLA only needs a 60°C heated table, while ABS need more than 100°C... for me its a little bit to risky to let the printer unobserved allone at home...
most of my files are from thingiverse.com.
after some weeks of experience, i found it really easy... i need about 5 minutes to prepare the files from thingiverse for the print.
it smells a little bit like melted plastic, but its not really disturbing... i play computer/paint/watch tv often while printing things....
when you buy a printer. buy a "finished" version with case. this "make it yourself" kits need a lot of more time to calibrate them... after 1 hour reading and looking 30 minutes youtube reports. i started my first print about after 2 hours, when i opened the paked on christmas...
the closed case is better, because the heat and a constant temperature remains in the cube. this is better for the "warping"...
and thats the update of my weekend. my printer had a lot of work to do.
at first: heres the result from the "impulse rhinoceros" from thingiverse... i think its a really good result.
after about 28 hours i also finished this monster-peace...
i included this woodstairs in the print file too.
Howie
Lead Addict
Nov 27, 2017
366
1,086
183
Uk
Awesome stuff! I'm sorely tempted to get one of these. Mostly for big bits of industrial scenery and basic shacks.
Reactions: Kommissar Shriken
