Squat Miner Rules
Took a stab at updating the old "Hi Ho - Squat Miner Gangs" rules for old edition Necromunda from Gang War 4, and adding/changing some things for Necromunda: Underhive (N17).
Here is my work in progress, which I'll be playtesting at our local campaign, keen for thoughts/suggestions/improvements:
https://docs.google.com/document/d/1IlzTjkfIXtCNTZG6j81NEgNKrxO_dCLuw_59VdHOVVk/edit?usp=sharing
Personally I would drop everyone's strength to 3, squat and dwarfs have always been S3 T4, there not space marines or humans but a happy middle ground. I would also drop the squat champions toughness to 4 as 5 is ridiculous, but at the same time I would up the Juves toughness to 4 and increase its cost by 10pts, ultimately a squat is tough because of its nature, not because it's waiting for drugs to grow his system.
I feel without that S3 T4 fundamental running throughout the gang you don't really have squats at all...
Have to agree with Major Svens suggestions. S3 T4 would feel better.
Honestly, the rules as they are are simply Goliath profiles with Escher Initiative (I 3+ is really good, I wish my dudes had that), and they also have a bunch of built-in skills, one that is simply awesome. (Nerves of Steel in combination with 5+ Cool! :eek:). And all for the same cost as a Goliath?
I think that if you want them to be Goliath++, you need to charge the player for it. Like, the gangers as they currently are are worth at least 75 pts per model.
Also, its because we started with Goliath profiles as a starting point and kinda went from there. Toughness 5 champ had to be a typo hahah.
I've made the suggested edits. Anything else that stands out as obvious before we start playtesting
An issue with the Goliath base profile is the bad Will and Int. It feels like the archetype Dwarf/Squat should have an Int similar to the Van Saar. They are known for being tech-savvy after all.
And the squat resilience to magic/psychics is also something they are known for, so they should probably be better than the average ganger there (a value below 7+ that's for sure). Now they are sort of weak-minded and dumb, but stubborn, something I don't think is fitting at all (well the stubborn part fits at least!).
I wonder if their M of 4" could be dropped to 3", or if that would make them too difficult to play?
It's difficult to price them fairly if they are just good at everything, and the worth of for example Will is currently almost zero. But it could become relevant in the future so that complicates things.
I personally would like to see them be slightly slower than Goliaths, but Move 3" might be too slow for them to be fun to play. A nice homage to the old RT/2ed/WHFB dwarfs though, who all had M 3". :)
M3" but really difficult to pin? Could that be their shtick?
As said, the cost is something that needs to be discussed with the people you play, some of the stats are really hard to simply assign a value to. Nerves of Steel is awesome on a dude with Cl 4+, but does little on someone with Cl9+ for instance, and going from M6" to M7" isn't really that big a deal, but dropping down from 4" to 3" could be a game-changer).
I gave this idea a bit more thought, since the models look pretty cool. :)
But anyway, trying to back-calculate what worth GW put to the different stats is a bit difficult, but in general I think the 'mental' stats are like 5 pts each, M is 10, S 15 and T 20. Flak/furnace plats are both 5 pts and mesh is 10 pts. By that logic an Orlock Ganger should be 55 pts and a Goliath Ganger should be 60 pts.
If we give a Squat Ganger a profile of
M ws bs s t w i a ld cl wil int
3 4+ 4+ 3 4 1 4+ 1 6 5 6 6
He would cost 65 pts plus armour. I think your dudes could well have mesh, so that's 75 pts, and the skills are a bit tricky. There is some dimishing return going on here, but 80 pts per dude might be resonable in that case.
If he costs 80 pts, the Champ could have a profile of
3 4+ 3+ 3 4 2 4+ 2 6 5 5 6
And cost 130 pts.
The Leader might then have a profile of
3 3+ 3+ 3 4 2 3+ 3 5 4 5 5
And cost 160 pts.
Juves would be without armour and have a profile of
3 5+ 5+ 3 4 1 4+ 1 7 6 6 7
Cost 45 pts?
Dunno if they are op or weak? Perhaps too expensive? The problem with goliaths as it is is that they have amazing buffs in the stats they use all the time, and bad values in stats they don't use at all (how often does a ganger need Ld for instance?)
If you/we can design rules ourselves, I think we should take the opportunity to think and regard our creations with a skeptical eye, to ensure our opponents have as good a time as us when playing.
But these rules might make the squats too weak. M3" might make them unable to properly interact with 3D terrain perhaps, if the floors are high enough. Perhaps this profile and cost is perfect if they get M4" 'for free'?
Dunno, things like these need to be playtested, armchair theoryhammer only get you... Goliaths. :p
Reactions: Major Sven
I would give squats M4 but give them some special restrictive rule.. Like a penalty to charge or a minus 2 on there second move if they do two move actions a turn... Might need a little thinking, something thematic but I feel M3 is too restrictive.
I feel like the stats and cost shown above is pretty good however but I would change Move to 4..
Reactions: totgeboren
I just tried to count backwards using Orlocks, Cawdor and Goliaths to get approximate costs of all the stats, but it's definitely a bit of guesswork too since it's not entirely consistent. (For example, Van Saar seem to get their Int 5+ 'for free', but Goliaths seem to get a discount for having bad Int)
What if we draw from war hammer fantasy a bit and allow them to always "march" at move 3? Getting into position to shoot will be important at low moves as charging won't be very valid.
You could try move 3" with a special skill. "Relentless" (similar to Sprint), if the squat takes two moves after they are both resolved they may take a free basic shot action. It isn't them scrambling for cover and snapping off a shot it is them taking an implacable advance while shooting. Shotguns and close range fire fights would be awesome for them where their t4 would shine but pinning them would still reduce some of their tricks. Thinking behind after both moves is to eliminate "pop out" attacks.
Maybe a special renlentless with a modifier to there basic shot (like -2 BS) but as is this is super powerful.. It would also encourage most squats to be arms with basic weapons only, and really one massive draw of necromunda jas a varied gang armed with all sorts of nonsense :)
I still feel M4 is the best way without over complicating the game or throwing in a powerful possibly game changing variable special rule
True enough special rules complicate things but if you are customizing up an entire crew you may as well go whole hog. This will actually encourage more varied weapons at mv 3 for the ganger level maybe champions and leaders don't have relentless but move faster to encourage cc. Doing something like this needs the whole picture for balance. I do agree mv 4 is easy and cleaner.
I wonder if the better way to do some of these customs would be to give a new primary skill tree to really tell the tale. Make the player take choices.
Relentless as above for a shooty champ. Sure footed scramble double the d3 for charges (assumes moves of 3 and 4) this keeps charge ranges within the current house gang ranges with a workable minimum. Then a couple of demolitions type skills, set traps open doors make holes in terrain to move through. And finally a surveying skill or two gain turf easier, or take actions during the game to pocket some credit worthy stuff from the battlefield (combat miner lol)
With M3 and Move+Move+Shoot, Squats would move faster than any other gang while shooting, and at the same time still have substantial difficulties with traversing vertical terrain.
To be honest, I never envisaged squats as super-fast agile gunfighters, nor do I think it would be fun to have to start next to a ladder to be able to fit your base on the next level.
So the relentless rule would basically fail both at conveying theme, and enabling functional game-play.
M4 is probably the reasonable middle ground.
I have been playing a Squat gang in standard necro for a long time so I thought I would weigh in.
Squats are an elite army and should be built as such. You pay a little more points for stronger base stats. I would plus some things up and ramp up the points. Their main weakness is low move speed, which is really crippling. M3 in base necro means its harder to get into melee, chase down fleeing units, and escape off the board in key missions. This coupled with the fact you have less dudes than everyone else really makes it so you have to plan you moves carefully. The balanced point is their extreme durability. Squats just don't die and never run.
We already have a squat bounty hunter so that should be around our base champion stat. He has:
3” 3+ 4+ 3 4 3 5+ 1 5 7 5 5. I can buy the cool being lower cuz a merc isn't going to be as loyal as a regular dude.
Prospector
3” 3+ 3+ 4 4 3 4+ 3 4 4 5 5
Champion
3” 3+ 4+ 4 4 3 5+ 2 6 5 5 5
Miner
3” 4+ 4+ 3 4 1 5+ 1 6 5 7 6
Slagger
3” 4+ 4+ 3 4 1 5+ 1 8 7 8 6
Nerves of Steel, Resilient, and Encumbrance look good. If prices need to go up raise them, but just remember the penalty of movement is a huge one. You are two inches slower than the standard ganger. You are also shorter. I am not sure the size of the AoS dwarf models or the new bounty hunter, but being shorter does help with a lot of the angles for fire when people leave lasguns or stubbers in high vantage points.
I am tempted to say all Squats should be specialists. Since you are an elite army with higher stats and costs and less models, you need to rely on making more specialized choices.
We also need to look at how advances and rules for what territory squats should grab. The fluff has always been they are illegal miners of sorts. Some of these options squats shouldn't be interested in. Others like the mine should get a bonus. This was key because of the expensive durable squats aren't dying as easily you need to limit their ability to easily get credits. I feel like you could mostly port the old rules from Hi Ho.
Just my two cents.
I would make them a little bit more different by giving them Strength 3. I would also make them less static with Move 4". I fear 3" move simply isn't going to be much fun.
I'd lean against making them too elite. Nerves of Steel feels a bit like a needless addition when it's already a skill and they are ferocity primary, so they can get it easily.
Looking very promising - I appreciate you taking the time to do this.
I wish I could offer some constructive feedback but at this point I've yet to even learn the new game - it's very different than 20 years ago.
I will be following this project with great interest.
