Poly Cement is an interesting one, I wondered why it doesn’t smell / get you high like it did when my dad and I built a Airfix Lancaster in the 80’s. New safe less toxic formula init Guv. Meh.
I have heard of people soldering models together and often wondered how they managed it without turning their lead figure into an impromptu T1000 model.I decided to be brave and attempt soldering the sword back on
Exhibit APoly Cement is an interesting one, I wondered why it doesn’t smell / get you high like it did when my dad and I built a Airfix Lancaster in the 80’s. New safe less toxic formula init Guv. Meh.
Stop using it as a mixer!! It might vaguely smell like pear drops…Tastes a bit nicer than it used to though. Tamiya Extra Thin is my favourite.
Did you use actual solder on the joint, flux and the like - do you have a variable temperature iron??
Those were the days…There was a time, many years ago, when people would literally give away models when they'd given up the hobby.
I imagine it’s going to be much the same as a miniature, just larger!! Probably a black weathering powder on the barrel vents to give a powdery finish.I've been weathering up Horg's-own-Boltgun from TribeMeet, suggestions of other wear techniques welcome.
