N18 Template / Blaze queries
JustMark
Aug 10, 2019
6
8
23
First time posting in the forum so hello everyone, my name is Mark and I have a current Necromunda addiction. (gaming butterfly tho so might be on something new by October)
We are running a campaign and there's something of a feeling that template weapons, particular those with the blaze trait are somewhat too powerful. Now I think there are actually two sides to this opinion for the record. Firstly we're all quite new to the game so it might be caused by inexperience and secondly the majority of us only own ZM terrain that potentially exacerbates the issue.
With that in mind would people mind sharing their thoughts on a) if blaze is too powerful and if so how do you deal with it and or b) how do you tactically deal with template and to a lesser extent blast weapons in ZM games?
Thanks in advance from some noobs...
Kiro The Avenger
1,536
2,021
128
The fact that you only play ZM is really exasperating the template issue.
But you're right.
Blaze in particular is very powerful. It's essentially a 50/50 chance to completely cripple the target with almost no defensive measures available. The only real counter is to equip Hazard Suits. However, this is a heavy compromise as they're just a 6+ save, which will leave you very vulnerable to being injured conventionally.
5,085
5,066
Blaze weapons are typically more expensive with shorter range than non-blaze weapons. You can calculate a fighter's threat range based on their move. This allows you to move at a distance from them, but also allow them to have board control.
Reactions: JustMark
JustMark
Aug 10, 2019
6
8
23
Thanks chaps,
To be honest I thought this might be the response. I'll carry on building more 3D scenery but in the meantime it's a case of back-off, spread out and generally be cagey?
Cheers
BdaGamer
Nov 29, 2018
12
8
Bermuda
JustMark, I have an opponent that loves blaze as well. I have learned to avoid the weapons when I can. The wielder is generally short ranged and I dedicate a ganger (or two) to keep them pinned. When you can avoid the blaze, remember that is does make you ruin around wildly which can be used to set his gang on fire, also make sure to try to put it out. Try to spread out and have less targets for the blaze.
I also have found a grenade launcher to be a great counter. :LOL:
Reactions: JustMark
Scabs
Feb 4, 2014
299
387
73
San Diego. CA, USA
Blaze is the cheapest and least limited way to counter high strength fighters, like Stemmers. It works against hordes or Ambots. And, one can fight fire with fire. I agree it can be a bit too universal. So can Grenade Launchers. But, be careful what you wish for.
Reactions: JustMark
JustMark
Aug 10, 2019
6
8
23
Cheers fellas, I don't personally believe it to be a problem at all but we had a player freak out about it and I thought I should ask on his behalf to see what the general feeling was on it's power in game and the ways to counter it.
