Hey all, I want to document my ongoing process of THE TOWER (I do need a better name).
This was built in 1996 at Gorilla Bob's in Spokane, WA. I was 11 years old when I first set my eyes upon it. It was glorious. It has now sat in storage for about 10 years at Merlyn's (also in Spokane), and last summer, I bought it from the owner, with the intent to bring it back to glory. I've started work on it. Initially, it consisted of just getting things back together: Reattaching parts with tacky glue and toothpicks (most of the structure is made from styrofoam).
I took Necromunda terrain pieces from the 90's and photoshopped them into full sheets I could then print out and apply. I am also using a combination of black poster paint and mod podge to paint back over places the styrofoam is showing through the paint.
Different Scales
Here you can see 54mm Inquisitor models up higher, with a smaller 30mm Tech Marine down below.
Chaos psyker in the hive
This model is a 54mm Inquisitor model, showing the scale works just as well at this size.
Another Side of Things
There are so many great small details here that you can find, along with different areas that...
Rough Shape
It was in a REALLY rough condition when I got my hands on it, needing a lot of TLC.
Backrooms
It sat back tucked away for 10 years in this game shop, kind of falling apart, needing a lot of...
One side
When it first got to my house, I couldn't fit it through the door, so I had to shave off the...
BEWARE
This is a model printed at Inquisitor 54mm scale, showing that the tower also works for those...
Progress
I have begun adding on sheets of Necromunda terrain to add more interest to the tower.
