Thnking outside the box with Heavy Weapons
I normally roll with 1 heavy stubber and flamer in my delaque gang.. and then upgrade to a 2nd if possible.
the ability to lock down corridors is useful. This time I am rolling with the Lascannon from the get go, purely because I have the mini and havent rolled with it before.
I find while the Heavy stubber has more potential to do damage.. there is a big fear factor with the lascannon.. you put him on overwatch and people are less likely to take that route, same can be said for the plasma cannon.. but with its blast you tend to be a bit more active with it to get the best shot possible. (I have a mate you runs Vansar all with plasma weapons)
I'm getting more and more into meltaguns, it probably depends on your gang and how close things get, but they are a lot cheaper than lascannons and you'll often get the same number of opportunities - namely that one crucial shot in no cover. Plus they have the advantage that you can hand them off to a specialist or to your leader if you want, or start with it on your leader then hand it off to a heavy that gets a bs upgrade.
I think lascannons are decent, especially if you are trying to cripple your opponent's gang. I don't think they are much fun to play against as they are really harsh and I think for that reason alone I wouldn't take one. I've found games where you have to stress about real, perma death are less fun for everyone involved. A melta-gun is still quite scary when it comes to injury rolls, but a lascannon is going to make people cry.
After all that's been said I'm actually strongly considering a missile launcher....
I'm 4 games into a campaign, I have an infiltrating specialist (currently with a grenade launcher), and the classic heavy stubber/flamer combo on the heavies. I've also got a fat stash of creds after two turns with high income and virtually nothing to spend it on.
The grenade launcher has been absolutely golden for me over the last couple of games, and I'm now thinking that with some reshuffling I can get two pie plates of doom onto the table.
My leader would get the grenade launcher, the flamer should go onto my infiltrator, and the two heavies can sit back raining S4 death.
Silly? Yes.
Fun? Absolutely.
Also the miniature is way too badass not to get onto the table at some point.
http://heresyminiatures.com/shop/index.php?main_page=product_info&cPath=2_15&products_id=130
I have a heavy with a missile launcher and BS3. Pretty much useless at actually hitting anything, but he will prevent the other gang from bunching up and make them nervous about straying into the open. The main problem is that a hard cover shot will need a 6 to hit, and then you will likely fail the ammo roll. You don't get a lot of bang for your buck.
On my list of things to do is get my escher painted. I intend on starting them with a lascannon for giggles. Sure it may take a game or 2 to hit, but my god when it does!
I know :)
But I absolutely love the idea of randomly lobbing S4 blasts across the table . The grenade launcher has given me the bug.
And I keep telling myself that I'm bound to get a BS upgrade soon....
I've rolled 1 a few times when I rolled To Wound with a Delaque packing a Lascannon and a decent BS. Really really disheartening. All the worse when your opponent then capitalises with a Heavy Stubber, which in my experience is a more than capable weapon.
If considering a missile launcher why not go for a far cheaper and mobile Grenade Launcher, the main difference is range but seriously I have never seen a Necromunda set up where you can draw line of sight to target an enemy that's anything close to that sort of range. Grenade launcher and Stubber work well, add in a leader with a plasma and you have a weapon for every situation.
the heavy stubber stays as prefered for the same reason that the light machine gun is used as team heavy weapon in real combat much more than it's alternatives. BECAUSE IT PROVIDES COVER. With a heavy you are expecting to pin or induce fear in your enemy. The SPECIAL weapons are much better at killing. Also: We're talking about STARTERS here, the stubber is cheap and reliable. The rest are basically ubber expensive and unfit for starting games. If you found heavy armor or other stuff like that. Or a model that's really worth going for the kill. On starter games it wuld be better to take bigger, more lethal, heavies. But since you haven't really gotten to the point where a model is too powerfull to not kill it or where you find heavy defenses. A stubber fits perfectly, the rest is basically overkilling, and with the exception of fear factor it has no true advantage over the stubber until much later on when you can get it with in-game credits. On starters it's better to go for the reliability and cheapness of a team defending weapon such as the stubber. After all current armies use it as their main heavy weapon too, that can't be a coincidence.
I've only used a lascannon once on my Delaques but I know my buddy held his breath everytime I leaned over it to check LOS.
Ofcourse then when I did get a shot and a hit, I rolled a 1 to wound. I foresee that happening more when I get to use it again.
