Tony Thunderhawk’s Pro Hover Tournament 2020 (Festive Event)
Cheer on your favourite insane riders!
  • Zephyr ”Mystery Maiden” Blurr
    Votes: 5 62.5%
  • Chancer" Chadman
    Votes: 6 75.0%
  • Kickflip”Nobb
    Votes: 4 50.0%
  • Neville
    Votes: 5 62.5%
  • Kurt Thunderblaze
    Votes: 5 62.5%
  • Vilnous "Van Halfling,"
    Votes: 4 50.0%
  • Total voters
    8
CaptainDangerous
Of the Green Flame
Yak Comp 3rd Place
Oct 30, 2016
4,992
16,909
288
Durham, uk
(December Festive Online Yak Event)
......Thank @Space Truckin....
Greetings yaks and welcome to a very daft online game that I just made up last night!
Everyone really LOVES the new Van saar hover boarders, right!?
So here’s your chance of flying your own, by entering the very first (possibly only) Tony Thunderhawk Pro Hoverboard Tournament!!!
All you need to do to enter is roll 30 online dice and post them to this thread!
For every five die, look for multiples and consult the trick chart!
Each multiple will give you a completed trick plus score, which is summed up to give your total run score!
if no trick is made (no multiple die) the run ends immediately and any score after is lost (you merely thought about doing that trick)
The event officially begins on the 1st of December, and will end sometime before Christmas Eve.
The first two weeks will be open hovering, so yaks may skim the sludge pipe as much as they like!
At the end of the two weeks, all competing yaks will be paired up in accordance to their highest score and will go head to head in a knockout tournament!
i don’t know how well this will work, but I’ll be back as soon as I can with the trick lists, and hopefully we can grind some adamantium and catch some fetid air together!
Merry Christmas All!
Cap
F3519EEB-B5F0-4D69-9163-B8B95A66588C.jpeg60FB86B0-7795-493F-968E-5EA496F4695C.jpegB150B227-6A58-462B-9FA4-91B5BA1A2715.jpeg9CCA7F32-6B95-42C7-8388-B5DB6B8AB4E3.jpeg4DECA742-23B4-4FBF-8161-EE7BACF360DD.jpeg7EB5904C-64F6-4483-A03C-8EAFEFA9D95F.jpeg
11 Ollie (/Zim) 0 (5)*
22 180 Ollie 50
33 Kickflip. 100
44 Heelflip 100
55 Nollie 200
66 Shove it 250
111 Impossible 250
222 Fastplant 250
333 360 Flip 300
444 Hardflip 300
555 Stalefish. 315
666 Indy Nosebone 315
1111 Tail Grab 315
2222 Method 315
3333 Mega Ollie 350
4444. Rocket Air 367
5555 Japan Air 367
6666 Benihana 420
11111 Sex Change 500
22222 Madonna 525
33333 Finger Flip 600
44444 Front Foot Impossible 600
55555 Kickflip to Indy 625
66666 Varial 800
Second Double (score multiplier x2)
11. Wall Ride
22. Nose Grind
33. Handplant
44. 50-50 Grind
55. Crooked Grind
66. Smith Grind
*if you bail mid run, and your last trick was an Ollie, it becomes a Zim and is worth 5 points.
Vert Trick list
11 Benihana. 420
22. Sex Change 500
33. Madonna 525
44 Finger Flip. 600
55 Front Foot Impossible. 600
66 Kickflip to Indy 625
111. Varial 800
222. 540 Flip 1500
333. Judo Madonna 1500
444. Double Hardflip 1500
555. Triple Kickflip 1500
666. 360 Shove It-Rewind 1500
1111. 360 Flip to Mute 1500
2222. Kickflip Underflip 1500
3333. Front-Back Kickflip 1575
4444. Fingerflip Airwalk 2000
5555. 540 Board Varial 2000
6666. Christ Air 2100
11111. Varial Heelflip Judo 2500
22222. Frontflip 4000
33333. Backflip 4000
44444. Kickflip McTwist 4000
55555. Burntwist 5000
66666. THE 900 8000!
Second double x2
11. One Footed Nosegrind
22. One Footed Smith
33. Casper Slide
44. Heelflip to Bluntslide
55. Darkslide
66. Primo Grind
IMPROVE YOUR HOVER/POWER.BOARD! (Only applies to the Open heats)
*For every 3 runs you complete (didn’t wipe out) you may select one upgrade from the following list:
Galvanic Antigravity Trucks - you may replace any one die in your run with a 1.
Transauric Grip Tape - as above, with a 2.
Volkite Power Bearings - as above, with a 3.
Plasma Washer Upgrade - as above, with a 4.
Thermic Bushing - as above, with a 5.
Haemotropic Deck Board - as above, with a 6.
*If you score more than 1700 points in a single run, then you have gained sponsorship from a suitably named Company/Brand (May only ever have one sponsorship, but may change allegiance should you score a another high score run - you’ve been poached!):
Sponsorship Deal - You may add or subtract 1 from one die in your run.
INJURY TABLE
if your run wipes out on a natural straight (1-5 or 2-6) then you are DEAD!
Note: a natural straight cannot be modified with upgrades or sponsorship.
otherwise, make a note of the first two die of the wipeout and discover your fate: all injuries have no effect on the game!
Note: with the exception of broken board, which removes any and all upgrades.
12-14: SHINNER
15: MULTIPLE INJURIES - D3+1
16: KNOCKED OUT TOOTH
21: ROLLED ANKLE
23: BROKEN LEG
24: BROKEN ARM
25: BROKEN NOSE
26: BLACK EYE
31: DISLOCATION
32: CONCUSSION
34: BROKEN FINGER
35: SORE JOINTS
36: ROAD RASH
41-53: CLOSE CALL/LUCKY ESCAPE
54: ASS KNIFED
56: SWELLBOW
61-62: BROKEN BOARD
63: HORRIBLE SCARS
64: IMPRESSIVE SCARS
65: SACKED -yes, that sack
1- stalefish 315
2- Nollie 200 +handplant (400)
3- Shove it 250
4 - shove it 250 + crooked grind (500)
5- 180 Ollie 50
6- heel flip + wall ride (200)
total= 1715
Open Heats Registration Table (Rider name+sponsor+/Advancements/Run Scores/(personal bests):
@Stoof /“Chancer" Chadman +Moira’s Boardshop+ - thermocouple bushings, Plasma Washer, Haemotropic deck baord - Swellbow - 1515, 1800, 1630, 1215, 2350,1280, 1900, 2530, 2097, (2660)
/Chad "Concussion" Fragman ☠ - Haemotropic Deck Board - dislocation, dead - 0, 1515, (1545), 1250, 1230, 2150
@CaptainDangerous /CMOT Junior - (1667), 1100
@Lyndon /Neville +RedYak Energy Drinks+ - Plasma Washers, Haemotropic Deck Board - 950, 1380, 1115, 865, 1765, 1750, 1500, 2355, 1665, 2250, 2230, 2345, (2380)
@Aulenback /Vilnous "Van Halfling," +RECAF+ -Haemotropic Deck Board, Transauric Grip Tape, Galvanic Antigravity Trucks - Lucky Escape - 1500, 1365, 1265, 1580, 1450, (2065), 1830, 1845, 1615, 2040, 1880
@MedMos/“Kickflip”Nobb +Moira's Boardshop+ - thermic bushings, plasma washers, volkite power bearings, haemotropic deck - dislocation, concussion - 965, 830, 0, 1315, 500, 0, 1730, 2000, 2030, 2115, 1250, 2400, (2500), 2400, 2330
/“Shove it”Hobb ☠ - dead (almost) - 250
@Scavvierising /Kurt Thunderblaze +Long Shanks Spanners+ - horrible scars- thermocouple bushings, heamotropic deck -1800, 800, 1315, 1880, 1365, 1965, 1200, (2350), 2050
@Punktaku /Zephyr ”Mystery Maiden” Blurr +Rat Wear Gear+ - broken arm, impressive scars, road rash - volkite power bearings, galvanic Antigravity Trucks, Thermidor bushings - 0, 2250, 1500, 655, 1585, 1400, 700, 1000, 500, 1665, 0, 1450, 1000, 1830, (2580), 2150, 1500, 1750, 1747, 2280, 2532, 2300, (2980)
TOURNAMENT TRICK LIST
11 Benihana. 420
22. Sex Change 500
33. Madonna 525
44 Finger Flip. 600
111. Varial 800
222. 540 Flip 1500
Second Double
11 One Footed Nosegrind
33. Casper Slide
55. Darkslide
66. Primo Grind
THE TONY THUNDERHAWK PRO HOVER TOURNAMENT 2020
Note: Upgrades Can only be used to improve tricks
HEAT A
@Punktaku /Zephyr ”Mystery Maiden” Blurr +Rat Wear Gear+2980
@Stoof /“Chancer" Chadman +Moira’s Boardshop+ 2660
@MedMos/“Kickflip”Nobb +Moira's Boardshop+ 2500
*Blurr 12,750 vs 0 (Lucky Escape) Chadman
*Blurr 10,450 vs 9125 Nobb
*Chadman 11,250 vs 6000 (broken finger) Blurr
*Chadman 13,100 vs 12,625 (black eye) Nobb
Nobb 5300 (lucky escape) vs 11,500 Blurr*
*Nobb 12,000 (black eye) vs 8250 (broken finger) Chadman
HEAT B
@Lyndon /Neville +RedYak Energy Drinks+ 2380
@Scavvierising /Kurt Thunderblaze +Long Shanks Spanners+ 2350
@Aulenback /Vilnous "Van Halfling," +RECAF+ 2065
*Neville 13,450 vs 3395 (broken board) Thunderblaze
*Neville 10,850 vs 9,600 (sore joints) Vilnous
Thunderblaze 10,325 vs 13,125 Neville*
Thunderblaze 7,850 (broken board) vs 8,970 Vilnous *
Vilnous 9175 (impressive Scars) vs 9975 Neville*
*Vilnous 14300 (900!) vs 5600Thunderblaze
play each competitor twice, 2+wins = automatic qualification, ties resolved by points, lowest scoring eliminated.
SEMI FINALS (best of 5)
Winner Heat A VS Winner Heat B
II Blurr vs Neville III
(1)11,150 - 13,550*
(2)*12,200 (shinner) - 0 (lucky escape)
(3) *12,800 - 6000 (close call)
(4) 10,500 (close call) - 12,700 *
(5) 14,500 - 16,500*
Runner Up Heat A Vs Runner Up Heat B
I Chadman vs Vilnous III
(1) 11,700 - 12, 525*
(2)*17,075 - 8825
(3) 11,075 - 15,000*
(4) 13,200 (broken nose) - 17,420!*
GRAND FINAL (Best of 5)
NEVILLE VS VAN HALFLING
Did a test run down the sludge pipe and I had at least one double in every set of five; having a run of singles to stop a run is unlikely.
Scored two hardflips, a kickflip, a heelflip, and two shove its (I had two doubles on the same line), for 1300 points; since this is just a trial run I'm not thinking of posting the screen shot since it shouldn't count - just stating what I got as a trial run.
Chad "Concussion" Fragman loads his shotgun to blast any sump detritus out of the way and lines up for a practice run...
He pulls a Fastplant, an Ollie, two Kickflips, an Ollie and finishes on a Nollie before crashing into a low hanging girder and plopping cursing into the Sumpway.
250+0+100+100+0+200=650. Must try harder :ROFLMAO:
It means he performed a simple Ollie! (Rolled double 1)
Speaking of Stoof: a very talented, smart and some might say, roguishly hansome yak has sent me some very good advancement rules! If you wish to improve your hover(/power)board before the grand tournement, check out the opening post for details!
And thus the ZIM was created:
Nollie+hand plant (400pts) followed by an ollie (0pts) to keep the run going then a spectacular wipe out to kill my combo.
Up to 405pts with the world's first recorded "Zim" which I totally meant to do.😉
I think I might have used all of my luck for this game in one practice run :oops:
Concussion Fragman steels himself at the top of the slugepipe, takes a barely-filtered deep breath of something vaguely resembling air and shoves off the edge... he launches up the other side into a Hardflip, coasting smoothly into an Indy Nosebone, followed by a Shove It Handplant combo, a Shove It 50-50 Grind combo, Indy Nosebone and finishing on a Nollie
300 + 315 + (250 x 2) + (250 x 2) + 315 + 200 = 2130
AND THE CROWD GOES WILD!
Big Chuck from HoverVans, setting up a vendor stall of sludge resistant hoverboarding footwear nearby, takes out a little black book and makes a note in it for the future...
*the panel of judges+ have set up in their obervasion Bastion*
*the smell of ‘notdogs’ fills the air from a hotdog cart with the signage, CMOT Dangerous*
THE 2020 TONY THUNDERHAWK PRO HOVER TOURNEMENT HOVER PARK AND SLUDGE PIPE ARE NOW OPEN!
You all have two weeks to improve your boards and try to catch the eyes of the sponsors!
Good luck yaks and safe hovering!
+this is the imperium, only one judge and 4 scribes, The Emperor protects.
The first contestant takes to the Pipe! He stands proudly at the top. Those who witnessed his spectacular test run yesterday watch expectantly!
He surveys the pipe through the mists rising from the trickle of slop in the bottom.
He pushes off the edge... and realises he forgot to activate the antigrav trucks on his board. With a screech of metal and sparks he slides down the pipe, hits a weld badly and is thrown flailing into the stinking slop.
The slime gently corroding his flesh disguises the flush of embarrasment washing over him as the crowd bursts out laughing. He drags his board from the pipe. Maybe next time...
(@CaptainDangerous - Is there a limit to how many runs you can make a day? There probably should be due to the upgrades available. 2 maybe?)
I think if you wanted to stay sane you might limit yourself to two runs a day!
As long as your runs have unique time stamps then you have my blessing to go balls to the wall!
Remember tho: you need three ‘clean‘ runs to get an upgrade! 😄😄
Reactions: MedMos and Stoof
The Captain grimaces as he watches stoof untangle himself from his hoverboard....
The Captain then lifts his arm+ to the small applause of the Notdog vendor....
1- Shove It 250 +nose grind (500)
2- Ollie 0
3- heelflip 100
4- hardflip 300
5- Nollie 200 + handplant (400)
6- Rocket Air 367
total 1667!
+an observant viewer might have noticed him throw some kind of incriminating power cable snipping tool....
Neville steps up to the pipe, sweat running down behind his mask and stinging his eyes. As he goes to push off, he falters and drops unceremoniously.
Luckily, he catches himself in a handplant heelflip, swinging into a 180 ollie followed by back to back nollies. He bounces off a wall with a hardflip, before finishing with a simple ollie and landing awkwardly.
100 x2 + 50 + 200 + 200 + 300 + 0 = 950
I've assumed for that first trick I count the higher scores first, not the order they rolled, so if I'm wrong let me know and I'll change it.
Edit for bad spelling
