Really getting in to making terrain now, and I decided to buy myself a laser cutter.
I want to build a whole load of terrain that is compatible with the aesthetic of Zone Mortalis, really fill a 2’ x 2’ board. Build it both dense, as well as high. Have it be compatible with the GW terrain.
Buying GW terrain is an option - assuming you’ve either won the lottery, or are committed enough to sell a kidney.
For most people in the real world, MDF is probably the bulk of what you’ll have to use to create the framework. There are some great designs out there, especially if you’re not so bothered about the details, you just want to build it, spray it up, get in and start gaming.
But what if you want to really spend the time to make the details look right? How easy is it to design, prototype and build with a laser cutter? Let’s try it - starting with the column as the basis of the framework!
A few prototypes later (I on #5 now) and it’s starting to come together.
Add a few 3D printed parts for little details. Getting there.
Do I filler in the gaps with the corner pieces? Yeah I guess so, want it to look right. Let’s do that, then time to sand, prime and paint.
Then repeat a few more times
