Hey guy's!
i am often asked how i make my pressmolds and i want to show you in a little tutorial, that its exaclty so easy like it sounds.
of course not each mold is perfect, sometimes you have to try it a second or third time, but it works!
also a good tutorial wis resin is here:
http://sirskofisworkshop.blogspot.com/2013/12/how-to-make-molds-with-oyumaru-resin.html
what do you need?
at first you need the pressmold. i prefer the original and cheap "oyumaru" but you can also use "blue stuff". it's the same material.
its like a clay when you put it into hot water and after colding its hardened.
so lets start:
for example i made a pressmold for some cool orlock-weapons.
the litte but important detail is to press the oyumaru on the edge of the weapons to get each little detail of the weapon moldet (this is also important for making molds from complete minis or parts)
second example are goliath-bodies
next step- adding the 2-component clay.
you can use greenstuff. but i prefer a 2-component resin material like "magic sculp" ... its "softer" and easier to press....
the important detail for a good copy is to "press" the clay into the mold to get each detail. after pressing you shoud smooth the surface (because dont forget we have two sides)
dont forget how the 2 parts of the molds should match.
now you have to press the two sides carefully but strong..
you can also make a frame from lego (i used it for bigger molds)..
and then the result... you can see i added too much resinclay so i have to cut a lot... but after cleaning it will look good!
and after some practise you could get really good and detailed copies from whatever you want!
i hope you like my little tutorial!
HAPPY PRESSING!
