Bug Underhive Tools won't progress to next step
naztek
Sep 18, 2014
78
131
68
Canberra, AUS
Hey there, I'm running into an issue trying out the Underhive tools for the first time. The following error presents itself each time I try to submit a change. Be it a gang creation, adding a gang member, or editing said gang member. The task completes, but instead of moving to the next screen, I get a blank page with the following error:
Warning
: ini_set(): A session is active. You cannot change the session module's ini settings at this time
Reactions: Malo
