Weapon Attachments
'Nickname' O'Shea
Yak Comp 3rd Place
Sep 28, 2014
632
1,051
Further to @SomeHairyGuy's suggestion in the high-end common weapons thread, some ideas for weapon attachments:
Bipod:
Can be fixed to lasgun, autogun or hunting rifle. If player does not move, gives +1 to hit at long ranges only.
Flashlight:
Can be fixed to any pistol, autogun, lasgun and boltgun. Player can ignore the effects of darkness when shooting. However it makes it easier for them to be seen by enemies, and gives the opposing gang a +1 to hit when shooting at the player.
Underslung grenade launcher:
Single use grenade launcher compatible with frag and krak grenades. Can be fixed to lasgun, autogun or boltgun. Range 18".
Bayonet:
May be attached to an autogun, lasgun or bolter. Gives an additional +1 to combat score if the player charges. Cannot be used in conjunction with any other weapons in CC e.g. pistols, swords or flails. i.e. you may not use the bayonet and parry with a sword in the same round of CC.
Underslung shotgun:
Short-barreled single-use shotgun that can be mounted underneath a lasgun, autogun or boltgun. Can only use solid or scatter shot.
Thoughts? Ideas for costs?
I like where you are going with this. The bipod and bayonet seem pretty solid. A few comments on the others:
Flashlight - should be able to declare it "on" or "off" when you shoot, giving you the bonus and penalty when on, but not when off. The way you have it written, it sounds like it is always on.
Underslung grenade launcher - I assume you declare which type of ammo is loaded into it at the start of the game, but this is not spelled out in your rule - leaving it open to be selected at time of shot, which doesn't make much sense logically.
Underslung shotgun - seems like it would be very limited in use since it can only use the simple ammo and only has one shot. Might be more versatile if it could use the other ammo types. Also, again I assume you declare which type of ammo is loaded into it at the start of the game, but this is not spelled out in your rule.
Reactions: trollmeat
Flashlight - Agree. Have to declare in shooting phase whether it's active or not. It's more a hazardous conditions type of tool but it's still a bit of character.
Grenade launcher - Yes, as per the standard grenade launcher you have to declare if your grenades are going to be throwers or shooters before the game. Also as per the std launcher it works via compressed air, so you can have multiple grenades available for it, but it will only fire one due to the small charge of air.
Shotgun - I didn't want it to be a full-on shotgun (otherwise why have it under-slung?) more an added extra. I thought given it's limitations it would be nice to at least give players the free choice between solid or scatter.
These are pretty neat! Regarding the bayonet, a friend has been trying (successfully) to rope me into playing Mordheim, in which spears confer the ability to strike first on the charge - would that be of any interest for bayonets?
It would have to be altered as there is no striking first in necromunda. you roll off to see who gets the upper hand and then determine the winners set of hits against the poor bastard who thought they could win.
a bayonet could be of use as a bonus to combat score in order to represent getting a jab off and winning the combat
I really like the underslung shotgun. It'd be pretty great for a lasgunner to be able to fire off a scatter shell once per game. The other shells I don't think are especially important (sure, I'd use a manstopper shell, but it doesn't really do anything a lasgun couldn't already do), but the scatter shell would be a godsend when opponents go to ground in heavy cover.
I'm not sure I'd ever use the flashlight as-is, even if it could be turned off. +1 for hit rolls is a pretty harsh drawback! I think it would be suitable just to have opponents ignore the darkness rules as well (ie. they can see everyone, but everyone can see them). I mean, that's still kind of a wash so I think it needs more of a benefit to be worth paying for. I'm not sure what benefit might be appropriate though; something affecting chance to hit would just make it a poor man's gunsight.
Aargh, derp! Sorry, I've been doing too much other stuff and haven't done Necromunda in a while.
Ok, modified flashlight:
Flashlight: Can be fixed to any pistol, shotgun, autogun, lasgun and boltgun.
At the start of the shooting phase a player may choose to activate his flashlight. If he does so he can ignore any darkness effects and shoot normally, however in the opponents following turn he may be targeted and shot at normally by the opposing gang. A flashlight can also be used to spot hidden enemies, and an activated flashlight adds +2 to Initiative for the purpose of spotting hidden fighters.
Foregrip: Can be attached to shotgun, autogun and lasgun. Makes the gun more maneuverable in tight spaces. Gives an additional +1 to hit at short ranges, and enables the fighter to ignore negative modifiers for fast moving or fleeting targets.
Tidied up a bit, suggested costs.
Weapon Attachments
Weapon attachments are common items for all gangs. Only one item can be attached to a weapon in any one game. They may be used in conjunction with gunsights.
Foregrip: 10c
Flashlight: 10c
At the start of the shooting phase a player may choose to activate his flashlight. If he does so he can ignore any darkness effects and shoot normally, however in the opponents following turn he may be targeted and shot at normally by the opposing gang as he has given away his position. A flashlight can also be used to spot hidden enemies, and an activated flashlight adds +2 to Initiative for the purpose of spotting hidden fighters.
Bipod: 5c
If player does not move in their turn, gives +1 to hit at long ranges only.
Underslung grenade launcher: 20c
Single use grenade launcher compatible with all grenade types except Melta bombs. Grenades must be bought separately, and it must be declared before the game whether they will be used in the launcher or for throwing. Short range 0"-8" - Long range 8"-16" -1 to hit
Bayonet: 5cr
Gives an additional +1 to combat score if the player charges (in addition to charge bonus). Cannot be used in conjunction with any other weapons in CC e.g. pistols, swords or flails. i.e. you may not use the bayonet and parry with a sword in the same round of CC.
[ALTERNATIVE]
Gives an additional +2 to combat score if the player charges (in addition to charge bonus), however any fumbles rolled are doubled in effect i.e each 1 rolled for the combat score gives a -2 modifier.
Underslung shotgun: 10cr
Can be attached to a lasgun, autogun or boltgun.
Short-barreled single-use shotgun - Can only use solid slug or scatter shot.
These prices all seem pretty good except maybe the grenade launcher. It's 20c, then the grenades are an additional cost, and they can't also be used for throwing. So it's essentially a trade-off: longer range for a single shot. I'd say that's an upgrade, but a lasgun with a frag grenade becomes a 75c weapon (in ORB costs anyway; I'm not sure of NCE).
I did umm and aah over the price for the 'nade launcher so am well open to suggestions. My thinking was that the grenades are not tied to it for every game - as with the standard launcher you can decide before each game what will be adapted for the launcher.
Same price but increase range by 2" or so? Or keep the stats and -5c from the price?
Which bayonet set up do you prefer btw?
Been thinking - why would the choice be your guys to either throwing potentially unlimited grenades (if you are lucky with ammo rolls) all game, or only shooting a single grenade? What I propose is that the underslung grenade launcher simply allows you to fire a grenade (other than a melta bomb) instead of throwing it, increasing the range substantially (i.e. to your 0-8/8-16 mark), and have a note about there only being enough gas charge for a single shot each game, so all other uses of said grenade type must be thrown. Ammo rolls would affect the grenade type, not the one-shot launcher, so if you throw a frag and fail an ammo roll, you run out and can't later load one to use in the launcher, but if you still have some choke grenades as well, you can still launch one of them.
Am I making sense?
It's the same as with the grenade launcher in NCE. Since grenade launchers fire a different type of grenade, I guess they're not interchangeable. either way, I think if my riflemen were close enough to throw a grenade I'd still fire the rifle for the better chance to hit. I'm just saying that to show that I don't think having the option to throw the grenade is really enough to make the launcher worthwhile at 20c plus ammo.
For the grenade launcher I'd probably cost it at 20-30c and it comes with a frag grenade (it's largely better than actual grenades at 20c, but I'm not tempted to use grenades so I don't think they're useful as a benchmark). Other grenades can be compatible because why not (I'd say the same about the shotgun, although I'd still only take it for scatter shells).
The foregrip I think is probably appropriate. It's juicy, but not a must-buy, and extras need to be tempting because that money could be going on more cheap gangers. A lasgun with this looks better than a boltgun for the same price, but the boltgun is another poor benchmark (or possibly everything else is; I suspect the boltgun is actually at a decent price and most other stuff is a shade too cheap). For 10c I'd use it, but also be happy not to use it. Seems fine to me.
For the bayonet I guess the second one looks pretty strong (a total +3 on the charge is pretty beefy, with only a 1/6 chance of the disastrous fumble). I like the fumble rule, but I feel like the first option is more like a 5c weapon. But then, I really dislike the Necromunda CC rules (I use a set adapted from Mordheim), so I can't really discuss it without grumbling under my breath.
Ok, point taken with the bayonet, +3 is pretty beefy. Probably the 1st option then?
Not trying to argue my case too hard with the 'nade launcher as I really am open to thoughts on this, but just so you know where I'm coming from, IMO the 16" or 18" range I feel makes the grenade a LOT more useable as a weapon as most of the time a thrown grenade will only have a range of 9", 12" at best, which is near-as-dammit charge range, and inside the SR of most weapons. Which is why they generally don't dominate games.
@Ambience327 I'm not sure if we are talking at cross purposes here as I use NCE, but the rules are quite specific in that grenades must be declared for to either be for a launcher or to be thrown pre-game. I wouldn't really want to mess with this mechanic as I like to keep things simple when it comes to homebrew rules, and it also has the extra aspect of nerfing the potential OP-ness of a cheap 20c 'nade launcher - How often would you get to shoot a proper launcher in-game...?
Considering making the shotgun scatter only, but then I can see it being nice to have a S4 solid shot knockback hit in reserve :D
In retrospect foregrip can be just +1 to hit at short range full stop, and that will cancel out the modifier for fleeting target.
The intent behind all this is just to allow a bit of specialisation and character for the bog-standard gangers, who otherwise are rather dully armed with the four most common weapons. I don't want anything to be over-complicated, and certainly not OP.
My thing about the grenade launcher is that while it does seem better than grenades, I think a more useful comparison is to the weapon it's attached to. Compared to just firing a lasgun, it gains a blast marker and a negative hit modifier, which is an okay trade but not something to pay big money for. Maybe I'm undervaluing blast markers, but I don't feel the availability of that option really makes the lasgun significantly better. It would be cute with smoke bombs, though. I might buy one if I happened across some smoke bombs.
Overall, my thinking is that any gear beyond 'ganger+gun' needs to be pushed a bit to make it desirable. If all an attachment offers is a roughly equivalent option, it's not really worth it compared to spending more on lightly-armed gangers (I make a small exception for the shotgun, but that may well be a product of my fondness for scatter shells. You (almost) never get worse than -1 to hit! They're great!). Lightly-armed gangers are already such a good way to spend money.
This might sound unexciting but I like the idea of the bayonet costing 5cr (just like a knife) and simply adding +1 to combat score on the charge. Pretty simple, pretty cheap; not as good as a separate CC weapon but helpful as a supplement. It would be very helpful for juves who want to try their hand at combat but are too inexperienced/unskilled that they don't merit a proper weapon like a sword. Plus, I imagine fluffwise it's easier to poke someone with a bayonet'd long object than executing thrusts/swings/parries with a sword or twirling a flail.
