Weapons and Equipment Direction
How should we handle the weapons in Imunda
  • Allow races access to only weapons that appear in there codex and a Common pool of weapons
    Votes: 4 30.8%
  • Allow races access to only weapons that appear in their codex unless they have a special rule
    Votes: 4 30.8%
  • Allow racess access to weapons in their codex as 1 step easier to acquire, but can use them all
    Votes: 2 15.4%
  • Allow any model to use any weapon to represent the spec opps element of Imunda or non standard tech
    Votes: 3 23.1%
  • Total voters
  • Poll closed .
I really like the idea of the double weapons.
I am against the 2 shots, it is very powerful in my opinion.
What about weapons that already have a ammo test auto?
Will a failed ammo/explosion render the complete weapon useless or just the barrel that shot?
Some options seem quite powerful if this is not the case, for some weapons are rarely used more then once (hand flamer, infernal pistol etc).
ah, sorry, i forgot a thing: the WHOLE weapon counts as a single weapon: if one of the two barrels explodes, WHOLE weapons shall be unusable until next game.
if just one barrel jams, instead, just that barrel shall be unusable until next game.
and I agree for the second shot: it was just a possibility according to the original 2nd edition "combi-weapon" rule.
and, at the beginning, I wrote "one shot AND ammo-test: auto" for combi/underslung/attachment weapons but I'm not so certain to keep them.
the simplest way to implement such things would be "like the actual exterminator cartridge plus the ecceptions i wrote in my precedent post" but, as I said, I'm not so certain about the "one-shot" because of the hth use.
but mine was just a suggestion; let's discuss about it and let's see if you too like those rules.
Cool. I've been a bit buried myself, but in the next day or two will add in some of the edits I proposed that seemed well-received, with suggested corrections from others, and try to mark the bits that still need tweaking to get to a consensus.
well, due to the fact nobody is posting, I'll post another inspiration of mine:
grapple-caster
short long short long S W s/m cost special
0-8" 8-16" +1 -1 2 * - ? grapple, COME HERE!
grapple:
the model bearing a grapple-caster can shot to a point of the scenery using the "targeting terrain" rules; if hit, place a counter on the target point and another one near the character shooting the grapple-caster to show the starting/ending points of the rope.
if the to-hit roll miss, roll a scatter dice; if the landing point is over the maximum range, the shot is null, else proceed as usual.
the grapple-caster automatically includes a pulley-harness [see below].
COME HERE!
the grapple-caster can be used as a weapon with the above profile; a model WOUNDED by the grapple-caster shall be pulled toward the shooter by 2d6" if the target will, or just 1d6" if the target pass a S test.
a large or huge target is pulled by just 1d6" [or 0" if he does pass the S test].
a model wounded by rope caster suffer NO wounds and is pinned only if he fails the S test but the grapple-caster shot IGNORES armor.
however a model pulled out of a tall building, will suffer falling damage as it surpass the building border as usual.
pulley harness - cost: 1tg
the pulley harness is a tool used to safely grab onto cables and cord and to traverse them without tightrope walking; anyone equipped with a pulley harness in contact with one of the two end of a cable/rope can, in the following moving phase, automatically move to the other counter, thus ending his movement phase as he RAN [so no shooting, etc].
the model counts as effectively moving through the "rope", so models in overwatch can shoot to the model traversing the rope as for normal rules.
a model hit by overwatch fire while traversing the cable must test to avoid falling like it was shot by a shotgun within 1" of a border.
