N18 What's the point of Digi Lasers?
The Cybernetica then seems to be a kind of endo or exoskeleton, which would indeed make sense if it boosts then fighter's strength. If it would improve Digi Lasers, then this would be the only gang which would benefit from it, which seems odd to have. I see them indeed as a 'bling-bling' kind of status weapon, rather than anything really useful. There seem to be as many exploitable rules and gear as there are really crappy ones in Necromunda though, so I would not be surprised if they ment it this way...
Digi probably should have been written as S-2 all along - it's a complete outlier as far as close combat weapons go.
The other weapons (at least in the old Comprehensive rules list thats the closest to hand) that have specified strength levels are: Las Cutter (9); Web Gauntlet (3); and Xenarch Death Arc (3).
Las Cutter is a Lascannon as a blowtorch. Web Gauntlet is silly string on a glove. Xenarch Death-Arch is an electrical zapper.
A great many Van Saar fighters are modelled with cables leading out of their central nervous system - it's entirely conceivable that their digi-weapons are wired into the circuitry of the cyberteknika.
Digi weapons have melee and versatile traits, both are triggers for the gamma level benefit (unless the either/or wording somehow cancellation this double-up of eligibility, which seems weird).
As mentioned, the fighter most likely to get the benefit is restricted to 0-3 of the digis, for a cost of 40 credits (tek) plus 75 (digis)
The list of other weapons you list and the Digi laser (which as well as the Digi multi laser from that Necromunda Apocrypha Blood in the Spire in Warhammer Community) are all the Melee and Versatile weapons that are not keyed to a fighters Strength. ( I think they are it at least)
They all have one thing in common. They are basically all guns of some sort
A mini las pistol, a Lascannon blowtorch thing and so on (love the silly string 😁). It will not matter how hard you swing them you will not make the laser bolt or space electric arc go faster or burn hotter, the silly strings real effects are in the sedatives and throwing string harder does nothing.
They are more like using a side arm in close combat than a club. You don't add your fighters strength to a las pistol or a plasma pistol shot in melee do you?
The Gamma and Omega benefits are applied to the fighters Strength characteristic not the fighters weapon. That's what the rule says. If it said fighters weapons or the fighters strikes that would be different. The Digi laser, and the others you and I have mentioned, do not involve the fighters personal Strength Characteristic at all so the Gamma and Omega cybernetics benefit does not apply.
The Versatile trait requirement in that cyberteknika is actually redundant given that it has all Melee trait weapons as well. All Versatile weapons have the Melee trait so why bother putting Versatile in as well? That's GW weird "editing" for you
By keying it to the Melee trait it does lock it out from the pistols with the Sidearm trait as they don't have Melee so you can't use the cyberteknika to boost your plasma pistol.
Your Archeotek only has a 0-3 limit on its starting equipment list, say your founding gang or when you use a normal trade action to buy equipment for your Archeotek. You can still visit the Trade Post and use the Seek rare equipment option to buy more if you want to go full Beware My Laser Fingers Mwahaha!
Or just get a Laser Cannon.
Reactions: libratorr
The Cybernetica then seems to be a kind of endo or exoskeleton, which would indeed make sense if it boosts then fighter's strength. If it would improve Digi Lasers, then this would be the only gang which would benefit from it, which seems odd to have. I see them indeed as a 'bling-bling' kind of status weapon, rather than anything really usefuone l. There seem to be as many exploitable rules and gear as there are really crappy ones in Necromunda though, so I would not be surprised if they ment it this way...
Great to see someone using endo or exoskeleton properly 😁
The fighter Strength is not added to a weapon with fixed strength. There is no option to add strength in the Digi laser profile just a flat strength of 1.
That cyberteknika states it adds to a fighters Strength Characteristic when using a Melee or Versatile weapon. The fighters S is not used in the Digi laser attack.
Yep they are a status weapon. Or as I put it. BEWARE MY LASER FINGERS MWAHAHA!
Sorry Reading the rule wrong. Thanks for clarifying!
You are welcome.
It does seem little odd it only applies to Melee (and Versatile which is redundant) attacks. Strength can be used for other things like smashing doors etc. Although Van Saar should be using Intelligence for many other strength options.
You are absolutely right versatile is redundant here and this is purely about the fighter's strength. It could have been as mentioned earlier a suit with wires to boost but that simply isn't the case. I would not complicate this further.
Another exception in addition to those already mentioned is close combat part of Necrotic beamer. And most annoyingly vicious jaws of borewyrn infestation has S3 but clearly a result of the beast's strength.
You ate absolutely right versatile is redundant here and this is purely about the fighter's strength. It could have been as mentioned earlier a suit with wires to boost but that simply isn't the case. I would not complicate this further.
That's another exception from the house of blade p92
COMBAT VIRTUOSO
Any chainswords, fighting knives, power knives, power swords, stiletto knives and stiletto swords wielded by this fighter gain the Versatile trait with a Long range equal to this fighter’s Strength characteristic.
These weapons normally doesn't have reach but they gained it.
