Why don't Marines jump?
Insurgent
Mar 17, 2016
489
510
Springfield OR
Am I the only one who has seen jump packs on the backs of Space Marines for over 30 years...?
Rogue Trader is a little bit before my time but I heard a rumor that Space Marines had a jump capability back then. Even in 2nd Edition it seemed a little weird that you could plainly see jump packs on their backs but that simply wasn't a feature they could use. Jumping is a big part of the OG Starship Troopers concept for Mobile Infantry (ie: Space Marines).
Don't all you Marine lovers rush in and tell me those are reactor packs and vent ports behind their sholders. The exaust on Choas Marine packs really accentuates the jump pack feel of the whole backpack they got going on. You can try to expalin it away as a "jet pack" that is only used in zero-G for boarding actions in the void. But if that is your explination you should be polite and agree that the backpack is essentially a grav-chute. I'll accept that as a viable answer, but I would like to see more folks incorperating obligitory grav-chutes into their marine builds. Even from a siloed 2nd Edition perspective it just makes sence, given we know how real combat actually workes in the 41st Millenium due to the glory of Necromunda 95.
Eldar Jet bikes went through a similar nerfing after 2nd edition, due to the insane tactical advantage they provided. I've heard similar commentary as to why marines lost their jump packs. It may have just provided too much complexity and tactical advantage on the tabletop. An imbalance they corrected by making what were full flight "jet packs" on marines into the "jump packs" of today you see on intercessors and raptors.
Whatever you want to say, its is one of the most glaringly obvious ret-cons of 40K that we still live with today....
Anyone want to venture how much an old school Rouge Trader Marine "jump Pack" would cost in Necromunda 95 credits? I would actually like to build a Necromunda balanced Space Marine that has full jump pack and grav-chute capability and see how he preforms against some Ash Waste Nomads. The Chaos Marine at the back of Outlanders is a good starting point but lets be real, most marines have more complex kit than what that lonley renegade has to offer.
Page 104 of the 1987 Rogue Trader sourcebook shows two Assault Marines with big jump packs. Pretty sure normal packs have just had exhaust vents since day 1 rather than jump capability.
Reactions: Aulenback and Stoof
Stabilising jets according to this old rogue trader diagram. So makes sense that they are used in low/zero G. There is one piece of artwork from back then of them being used as some sort of jump pack or grav chute. Wild times lots of ideas being thrown in the melting pot.
The HH books by forge world introduced anvilus pattern back pack essentially the chaos back pack. It goes on about it being used in low/zero G. Being used in such a way does not imply it's got enough oomph in it to work a grav chute for an armoured marine.
Although weren't the guard issue jump packs basically marine packs? So maybe there is a case for them being used as grav chutes or jump packs on regular sized humans
Reactions: Stoof and Aulenback
I heard that at one point, in the WD write in question things, the players were asking about why the marines didn't leave cracks everywhere they walked or fall through the floors of ruined buildings. Apparrently, the GW official response at the time was that the power packs also have some degree of anti-gravity that prevents the marines' full weight from affecting the terrain.
I don't know where this is written down, it's something I was told by someone more knowledgeable about WH40k fluff, back in the day.
As far as I know, this is no longer part of the fluff, but they've also substantially increased the size and durability of GW ruins both as sets and when pictured. These days, the imperium clearly designs regular homes to be space marine compatible ruins, some day.
1989 Rogue Trader book space marines with jump packs, just a few pages away from the "stabilizer jets" image linked above:
So the Jump Packs looking like later editions' jump packs goes right back to the beginning. For what that is worth.
