Necromunda WIP by jim
9,932
13,231
Alobar said:
If that was me I'd be worried of self harming with that third arm. Can you add a protector shield thing like on a lawn-mower!
And yes, I know the answer will be no and I'm just being a pussio!
For all the hazard strips you see around necromunda, they are surprising lacking in any other form of HSE. Clearly all the Safety budget went on yellow and black paint :p
Blood Donor
Enforcer
Aug 23, 2011
3,479
4,572
198
33
Cranbrook, British Columbia, Canada
With a full board of such cool terrain you need to:
a) PAINT THE DAMN WOODEN BOARD ITS ON!!! The terrain deserves it and it will tie it all together. Even if its just matte grey, its gotta happen. Because,
b) You need to make a thread with play-by-play photo journals of games you play. Seems you have a good group going that plays often with nice colourful terrain and a good assortment of gangs. It will help get people into Necromunda and help them learn game mechanics if there are battle reports on this site ripe with pics. You could edit photos and draw in arrows to show where models moved on their turn, and really capture the action!
I'd love to do all this myself, but I think you are a lot closer to being able to pull it off without the board and gangs looking 12% done.
jimjimjimmyjim
1,467
176
83
38
flemington, Victoria
Painting the boards is at the bottom of my to do list, I'm trying to get enough terrain first to complete 2 entire boards of necromunda terrain.
Anyways here's one of the big pieces I have been working on lately:
Anarkitty
May 18, 2012
80
12
8
Redmond, WA
Looks like "hardware cloth".
Any big-box hardware store and most smaller ones should have it in big rolls, and it comes in square-sizes from 1/4" to 1". I use it for railings and ladders.
cardyfreak
Sep 15, 2012
3,620
5,139
178
37
Alnwick, Northumberland
yaktribe.org
There are a few things you can use as fencing-
In order of quality of finish/look-
1- car body repair mesh; this stuff is sold in sheets by car accessory shops. Whatever is your local car shop that sells things like car cleaning products and other car maintenance things. There will be a section that sells things for repairing bumps and damage to the bodywork of cars. This is where you'll find the repair mesh.
http://item.mobileweb.ebay.co.uk/viewit ... 0846725600
2- plastic canvas, aka 'granny grate'; find your local haberdashery or sewing shop. Ask for plastic canvas. It comes in 'counts', these being the squares per inch. The higher the number, the smaller the squares (so seven count has bigger squares than 14 count)
http://www.ebay.co.uk/bhp/plastic-canvas
3- plasterers scrim tape; this will be found in a DIY shop or builders merchant. It is a tape used for sealing joins on plaster board. It looks like a big roll of tape but with holes in it.
http://www.ebay.co.uk/bhp/scrim-tape
The car mesh looks the best but can be bent easily.
The plastic canvas is the most robust. Make sure you seal it before painting with either varnish or pva cos paint just peels off it.
Scrim tape is quite flimsy but is by far the cheapest for the amount you get. I use this more for lining things than for fencing, but I have used it as fencing. It works better if you double it over on itself. You can also get some cool effects by brushing it with watered down PVA before painting.
jimjimjimmyjim
1,467
176
83
38
The stuff I use came from the rooftop of my neighbouring building. Whenever they have maintenance done they tend to leave all their off cuts just lying around which is actually quite dangerous cos it gets very windy up there and anything small or sheet like has the potential to be picked up and blown off the roof.
Anyways I tend to take this opportunity to jump the fence between our 2 sides of the building and go foraging for treasures.
chitching
Sep 12, 2012
1,129
814
32
Alternatively, you could try looking in Hobby/craft shops. I found a roll of the stuff for a couple of Pounds (£ not lbs). I don't know if it's something all craft shops sell, but it was between Model railway scenery/track and fashion mannequin foam heads. It is a really good thing to use for fences, like has been said, but also for walkways, panelling for buildings, making scenic bases or even for giving vehicles "Hillbilly armour"
